12-01-2011, 03:27 AM
Mein Auto: X5
Originally Posted by gerry9870
Hey There
I willhelp as much as I can,,but I need to some more details, does the car display the symptoms when it is cold or warm, have you lost the kickdown gear, can you use your gearbox in maual mode, has a message TRANSFAIL PROG appeared on the dash, when you select drive does the car take a few seconds before it engages gear, but you experience a loud thump before it moves off.
Cheers
Gerry
Hi Gerry,
Thank you so much for your fast reply
There's nog change in temperature these days so I don't think it has anything to do with heat or cold. I can use the gearbox in manual mode but it still takes a few seconds before the car actually moves slowly and it makes a noise (it's the same movement and noise when I put it in D). When I put it in R it starts to drive forwards immeadiatly without making any noise.
