G'Day,
Also check the switch on the clutch pedal . If it is not open, then the cruise thinks that the clutch is depressed and it holds the cruise control off . Usually, it is a slightly tweaked bracket that holds the switch in position to contact the clutch pedal arm .
>>Tim
