12-11-2011, 11:20 AM
Mein Auto: 650i Convertible
Soft pedal
These were great! Yorgi, you must be either an engineer or a brain surgeon to be able to document this is such great detail!
Did my rear brakes yesterday. Won't tell you how long it took to do the first, but the second only took about 90 min from first jack up to testing.
I used Hawk HPS, will let you know.
Also changed stock lines to SS, and installed Power Slot slotted rotors, and bled the system. My pedal feels a little soft at first application, but gets firmer if I pump a little bit. Any chance I screwed up the bleeding?
Going out now to try breaking in the pads again to see if that helps.
Thanks again. Looking forwad
