Old 01-03-2012, 08:27 AM
pburnett pburnett is offline
Mein Auto: 2006 BMW X3, Lexus IS300
Originally Posted by angina View Post
ugh, now my ABS and Brake lights are back....
2 things. Are you sure that this is the problem? The 4x4 light should have gone off as well. Also, when you did the gear turn, did you turn it 180 degrees? If you only turned it 90 degrees it is likely that the gear is still in the damaged portion.
