Old 01-06-2012, 03:20 PM
JoeFromPA JoeFromPA is offline
Mein Auto: 01 M5, 08 535xit
I believe they use the starter (I'm not sure how you'd fire the next cylinder without using a starter to move the piston- the stroke goes fuel spray, compress, fire - so you can't simply ignite fuel that's sitting on the cylinder walls and you can't have it spray and compress without moving the piston - so no matter what you need a starter to get that going...)
Bear in mind it's not your typical ignition starter - a start/stop starter has much greater mass AFAIK
F80 m3 - 20k miles as of April 2015....08 535xit - 120k miles
