Bimmerfest - BMW Forums - View Single Post - What's this Auto Start Stop Thing All About?
Old 01-06-2012, 03:40 PM
SoonerJohn SoonerJohn is offline
Mein Auto: 2012 335i Sedan (F30)
Originally Posted by JoeFromPA View Post
I believe they use the starter (I'm not sure how you'd fire the next cylinder without using a starter to move the piston- the stroke goes fuel spray, compress, fire - so you can't simply ignite fuel that's sitting on the cylinder walls and you can't have it spray and compress without moving the piston - so no matter what you need a starter to get that going...)
Bear in mind it's not your typical ignition starter - a start/stop starter has much greater mass AFAIK
It is definitely possible to do it without using a starter motor. The computer determines the best positioned cylinder, it shoots a fresh shot of gas in, and fires the plug and then just keeps on firing the other cylinders as normal. The only good professional explanation I can locate quickly at the moment is a PDF, but here's a link: http://www.etas.com/data/RealTimes_2...6_01_34_en.pdf
