Does the problem still occur in reverse? The reason I ask is because although you have replaced the shock tops I wonder if there is a problem with the turrets ie elongated mounting holes. So when the problem occurs it feels like your on full lock but as the top of the shock "slips" in the turrets allowing the steering turn a little more. Is any of this likely to be the cause
