Old 01-18-2012, 06:39 PM
DerStig DerStig is offline
Mein Auto: 2011 M3 E90 ZCP DCT
Originally Posted by bmw2012 View Post
I've taken my 2011 528i to the BMW dealer several times to try and find out what is causing a high pitched frequency noise that is coming from the front end of my car, but they can't figure it out. Has anyone experienced this or have any suggestions on what it could be? Thanks.
Does it come in high speeds? It's most likely cracked windshield seal, most dealerships won't take enough time to figure this out, there is not much you can do. Try lowering your windows just a tiny bit to have some air circulation (or open up the sunroof if you have one) and see if the noise goes (it most likely will). If that's the case, then it's the cracked windshield seal.
