Bimmerfest - BMW Forums - View Single Post - 2003 X5 battery drain because clock/radio comes on when temps go below 40 degrees
Old 01-23-2012, 11:32 AM
motordavid's Avatar
motordavid motordavid is offline
RetiredBum
Mein Auto: '01 X5 3.0 '02VetteVert
Originally Posted by Brwiskow74 View Post
Thanks for the info! This problem started last winter when we first moved to WI from CA, which is why it hadn't happened earlier. We couldn't figure out what was happening at the time, and then by spring, and new battery the problem seemed to fix itself, until the wonderful WI winter hit and the temps dropped again. I will call the dlr today to see what we can do! I was hoping for something easy!
You are welcome...I would bet a good '89 Bordeaux that is the problem.
Press the dlr, as I suspect they haven't 'done' that re-program in a long time, but the details are in that TSB, and the dlr can hump the info from BMW NA.
I would rec'd a good battery maintainer, eg Battery Tender or CTek for non-driving periods, or an occasional overnight good 'juicing'. Simple to connect under hood on the poz & neg lugs.
GL, mD
Ol'Uncle Motor
'01 X5 3.0 Sport, 5 Spd Manual, etc.
'02 VetteVert 6 Spd, Z51 susp.
'10 Hyundai Tucson for the CEO, & 3 Assorted M'Cycles.
BMW CCA mem. Tarheel Chapter
My Flickr...Scenes,Cars & Road Trip Pics:
http://www.flickr.com/photos/45275375@N00/
