Bimmerfest - BMW Forums - View Single Post - Operation .5 liters per cylinder.
Old 01-27-2012, 03:15 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
Originally Posted by Dino1394 View Post
From what i read Chip, is that you can use m54 cams
think you have to grind/cut one of them (exhaust?) so it fits into the M50TU head
yeah, i seem to think that i saw this on here as well. can't remember where, though. maybe in one of the links on hakkenTT's thread??
i also did some research on the m50/s50 and the head is the same part number, so i would assume that the cams would have the same journal specs and fit, just stick out farther on the exaust side where the vc & timing cover won't match up.
if the timing chain will line up, just grind down the rest of the camshaft nub to fit.
seems to make sense to me...
df
