Old 02-03-2012, 11:57 PM
MCSL MCSL is offline
Mein Auto: 330i
The TS030's hybrid storage system, developed by Nisshinbo, eschews batteries. Instead, capacitors are the energy storage medium and they are located opposite the driver in the cockpit. Toyota confirmed publicly that the test car is currently set up to power either the front wheels (system designed by Aisin AW) or the rear wheels (designed by DENSO) with their hybrid powered motor systems.
Obviously the 3.4-liter V8 powers the rears, but the technical decision is where to place the motors for the hybrid power. According to the rules four wheel drive is allowed, but with one exception: you can't power both front and rears at the same time, that is, they hybrid system engages when the V8 is disengaged and vice-versa.
But where to place the weight in the chassis becomes the concern with the hybrid system. And as the rules allow freedom of where to direct the drive, this is an area where some thinking will occur before execution. Toyota's current test program will evaluate which is optimal within the regulations and make a decision at a later date.
http://www.mulsannescorner.com/newsjan12.html
http://www.racecar-engineering.com/n...brid-revealed/
