Bimmerfest - BMW Forums - View Single Post - Info on recoding a used key & remote inside's
Old 02-08-2012, 07:45 AM
HerbP HerbP is offline
Moderator
Originally Posted by PAPER View Post
I decided to open up a used key I bought .
I will post pics to show you a common
problem with some of your buttons
not working . I will also point out the chip
you need to change so you can have the
key / remote Re-Coded for your car .
1st pic - button that broke loose from sauder .
2nd pic - spot button belongs
3rd & 4th pic - housing
5th pic - chip you need to replace so you can have a used key Re-Coded
Sent from my GT-I9100 using Bimmer App
I was not aware that this could be done? This should be added to the DIY!
