Bimmerfest - BMW Forums - View Single Post - DIY: BMW 650i / 645Ci / E63 / E64 Oil Change and Check Control Reset
Old 02-12-2012, 01:25 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Originally Posted by mrtwo2 View Post
thanks for the wright up. it should be a sticky (a post thats permanent ) for all. How about a brake wright up. I have gone through this process but when I get to the reset. I release then hold, the #s clear out but return. Am I doing something wrong?
The brake rotors and pads DIY is here.
The brake pad reset procedure is exactly the same as the oil, you just reset on a different icon. If the numbers are positive then that is the mileage until the pads need replacement. If your numbers are negative before and after the reset keep trying the procedure a few times. I have had cases where it took 2 or 3 resets before it actually "took". You should see a positive number around 32,000.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
