Bimmerfest - BMW Forums - View Single Post - Rims for 2011 Z4 3.0i
Old 02-15-2012, 07:16 PM
Volenmere Volenmere is offline
Mein Auto: 2009 X3
Originally Posted by HerrK View Post
OK for your training as the ET gets smaller the outside edge of the rim is moving outboard. So the F&R rims are 1" wider than stock. That equals to 1/2" on each side. For the rears you have to add another + 15mm because the ET is going from 40 to 25. The bottom line is the outboard edge of the rear rim is going to move outboard a little over 1" and your rear tire will likely rub badly. The frt rims would probably be OK.
Thanks Herrk, sounds like I should just pass on the rims. Appreciate the help, if you have any computer problems let me return the favor
