02-16-2012, 02:32 PM
Mein Auto: 2005 750i
Originally Posted by stuartjohn24
can the same coding be done with NCS expert?
Thanks again!
Yes. Read the module (MMI in this case) with NCS expert and you get the NETTODAT.TRC file which contain the command lines Ace is referring to.
You can modify the hex value on line 3002 as per Ace's guide and save the file as NETTODAT.MAN then code the MMI using the basic functions/coapiCodeSgByNettoDATA Type "NETTODAT.MAN".
