02-16-2012, 03:16 PM
Mein Auto: BMW E65 745i
Originally Posted by AceFX
Hey Stuartjohn24,
I haven't installed a Bluetooth antenna yet under my centre console.... the old TCU had two antennas plugged into it. One was for GSM and the other was for WDCT. I plugged those two into the new TCU and presto, the Bluetooth is working off the WDCT antenna which is on the rear parcel shelf. Of course this is only temporary until I install the correct antenna under the centre console....... but it is working now as you have seen in my videos.
The TCU does not need any coding other than changing the VIN in it to match your car. I did this using Dashsoft.
The facelift MMI will give you the access you need to the Bluetooth Menu. I did not try this on a pre-facelift MMI as I was not interested. I wanted the facelift MMI with more colours, better graphics and faster processing. Remember the MMI is the 'Brains' of the system.
Ace
Hi Ace,
Oh I see, luckily I may be able to do the same then!
I have a feeling the old MMI wont have the option to enable the bluetooth function, in which case I will need to upgrade this first.
I already have the upgraded facelift nav computer (navi03) which is loads better than the original navi01! and the interface is much better!. Again i need to change the VIN on this unit because the BMW assist dosent work and I cannot seem to upgrade the unit to the latest software... thats another problem anyway!
This dashsoft does all the required coding you need to retrofit the newer modules? can the software work with different interface cables?
Stuart
