02-17-2012, 07:13 AM
Mein Auto: 2005 750i
Originally Posted by AceFX
Hey Politby,
Command line 3002 ASCII code 7, which in that command line you have sent me is 3D. Change 3D to 3F.
Ignore 00300200, 0010, then start counting each pair....so the one that is 3F is the first pair, 2A is the second pair, 28 is the third pair and so forth.
There is a total of 16 pairs in command line 3002.
Ace
Thanks, I was wondering if you meant the actual decimal 7 or the hex value. Will change and try again. Guess I will have to setup an XP partition to run this Stone Age software from...
