Bimmerfest - BMW Forums - View Single Post - Is that a catch can? Yes it is. Goodbye CCV
Old 02-20-2012, 11:09 AM
bimmerteck bimmerteck is offline
BMW Magician
Mein Auto: e30 M50ish
Originally Posted by eparayno View Post
Everything is buttoned up. New problem now though. During idle the hose I have going from the PCV to the intake is compressing, the hose becomes almost flat. Is it the valve or the hose? Maybe the valve is on backwards? I have it setup like how it is on the 1.8T engine but that application is forced induction.
I believe your on the right track, although it looks good installed you will likely find that the PCV valve from the 1.8T is not a good match for your motor due to it being engineered for a forced induction application.
The valve you're using was never meant to regulate manifold vacuum as the 1.8T uses the suction within the turbo's intake for PCV function, not manifold vacuum.
Good advice is always certain to be ignored, but that's no reason not to give it.
Local to TN? TNeuros - Praise the lowered? Stanceworks
