Old 02-22-2012, 02:55 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
Originally Posted by fabby318is View Post
Sorry to thread jack somewhat, but Bimmerteck can you please supply me with more info on your dry sump system...any pics installed? Thanks.
That's what PM's are for.
The new valve that I'm using is used on a 3.2L V6 Chrysler engine and is $3 At auto stores. If one wanted to use the stock CCV to control vacuum then install of a catch can would be super easy. My aim was to eliminate the stock CCV. The check valve im using is in such a convenient place now(routed under the MAF sensor intake tube). I will upload new pics once I get a chance.
Heres a pic showing how you would run a catch can with the stock CCV using the stock hose attached to the valve cover.. The hose on the bottom of the CCV would have to be plugged and the port on the dipstick tube capped.
