Old 02-28-2012, 06:17 AM
TerraPhantm TerraPhantm is offline
Mein Auto: 2005 M3 Coupe
Originally Posted by ffej View Post
Pretty much. I'll check into the differences between the diagnostic and DSC systems. Thanks for the info...
edit It looks like both cars run the same Teves MK 60 DSC III system. Should be good there. /edit
Maybe I'll just do the whole freaking wiring harness
DSC should be okay - I just remember that one of the 01s I worked on had a fairly early variant of the Mk60 module, and that my old ZHP had a fairly late variant. Worst case scenario, the module should swap over since the connections should be the same.
Also make sure to grab the LCM from the ZHP so that the cluster doesn't throw a tamper dot. It'll have to be recoded to work with the touring's taillights, but that's trivial. What you'll then want to do is wipe the FA from the cluster and LCM, and copy your touring's ZCS to the "new" EWS and cluster, just so your car is still seen as a touring. The DME being newer than what it's supposed to be wont hurt anything there
When you're closer to doing the electronic/coding part, feel free to PM me; I'd be glad to help out as much as I can.
