Bimmerfest - BMW Forums - View Single Post - The "ZHP" Wagon is ON!!!!
Old 03-01-2012, 12:59 PM
SlimKlim's Avatar
SlimKlim SlimKlim is offline
Speed is Zen
Mein Auto: Bavarian Bombshell
Originally Posted by MalibuMafiaV View Post
Yeah Slim said it pretty well. AS long as it's stick shift and the transmission matches the wiring harness you should be fine. If the computer was originally auto than all you'd have to do is set it to manual from the factory with programming.
That does make me think of one possible speedbump. I wonder if the 5 speed coming out of the wagon will have different connectors than the 6 speed going in? Even so, the reverse sensor from one trans to another can't be all that different, you could probably just spice the connector from the new trans onto the harness in the wagon.
Maybe you mentioned it in your original post, but are you planning on facelifting the wagon or will this be a pre-facelift ZHP?
