Old 03-01-2012, 06:33 PM
icuc's Avatar
icuc icuc is offline
Mein Auto: 2012 X5, 2012 MINI ALL4
Free coding in Madison, Chicago and Milwaukee area
I'm based in Madison, WI and I'm willing to travel to Milwaukee and Chicago area if there is a group interest.
I may not be checking this board or PM very often so please contact me at -> bmwminicoding [at] gmail [dot] com
The following options can be coded in your car
Doors & Mirrors
Close Windows & Roof / Convertible top with the Key FOB.
Eject Key FOB and Unlock doors when the ignition is turned off
Disable Auto Dimming mirrors
Close Side View Mirrors with the key FOB
iDrive
Disable iDrive [Accept] Warnings
Disable Rear camera warning Never solely rely on camera
Video in Motion for CIC
Weather Band Radio for CIC
Fuel Stop Suggestion in Route Guidance for CIC
Lock/unlock beep options in iDrive for CCC
Day time Running Light option in iDrive for CCC
Traffic Information for CCC
2012 Navigation Maps Update for CCC
Wiper Operation
Wiper completes the cycle when ignition is turned off
Disable Headlamp Washer
Rain Sensor
Close Sunroof when the rain is detected (Rain Sensor should be turned on)
Instrument Cluster
Digital Speed in cluster (True car or Speedometer)
Disable Door Chime when the key FOB is in the slot.
Enable Efficient Dynamics Gear Shift Indicator (6 Speed Manual Transmission) 2007.3+
Instrument Cluster Lighting always On (Day & Night)
Red Clown Nose Blinking when locked (no alarm installed only E46& E83)
Instant MPG (Only for ///M)
Fuel Tank Warning at 1/8 tank rather than 1/4 tank
Frost Warning (Chimes when below 37'F - only E46)
Lights
Double Blink Hazard lights
Side Marker/ Turn Signal Lights / Corner LED off with head lights
Disable windows safety feature (One touch window rolls up when door is open)
BFD (Brake Force Distribution) Lights on with regular breaking Very bright break lights
Increase Brightness for Angle eyes
Fog Lights stays on with high beam or high beam flash
Fog lights always on with headlights (low beam, Auto)
Fog lights on with AE DRL
Fog Lights for Corner Lights (Fog lights will turn on for low speed turning)
Welcome Lights on (Turn on fog, Angel Eye, low beam, rear license plate lights when unlocking the car)
Follow Me Home Lights (Turn on low beam and break lights when trunk release button pressed once - FRM3)
Angel Eye on full power when low/high beam turned on (No Angel Eye dimming) Not for LED halos.
Angel Eye as DRL instead of head lights
Rear Tail Lights ON with DRL
Delete Bulb Errors (Disable Cold/Warm Test after Retrofit)
Adjust the Auto Light Sensitivity (Head lights will not turn on when it is sunny)
Trunk
Close the trunk (tailgate) with the key FOB and button inside the cabin
Seat Belts
Remove Seat Belt Chime for Driver and Passenger
Others
Retrofit Coding
F Series vehicles are not supported
*Possibility to code specific option may vary depend on the model. I'm not liable for any and all possible damage and worry not though! In 50+ that I've coded I have not had a single coding-related error.
BMW (Remote) Coding for E Series, F Series and G12 Models - www.bmwminicoding.com
