Old 03-10-2012, 01:20 PM
Germane Riposte's Avatar
Germane Riposte Germane Riposte is offline
Go Hokies!
Mein Auto: 2001 325i Touring 5-speed
I had the opposite problem with my Touring; the glass popped open all the time by itself. I played around with the window lock mechanism, adjusting the striker, etc., but it turned out to be a short in the button under the wiper.
With the opposite condition, a window lock failed closed, I don't see how you can get to it to replace it if you had to.
Here's the page from TIS Spaghetticoder on removing the window lock:
Piece of cake...but it says to first remove the trim panel inside the hatch:
You can't do Step #1 because it's covered by the stuck-closed glass. I suppose you could hack a hole in the plastic trim panel to access the window lock mechanism, but there has to be a better way if you have a known bad lock. This situation has to have happened before.
Obviously, non-destructively searching for electrical gremlins is the first thing, as others have mentioned. Perhaps there's a point down below the D pillar where you can access an electrical connector and see if the car's lock module is sending +12V to release the window lock when it's supposed to.
