03-13-2012, 08:27 AM
Mein Auto: 2003 E66 760Li
Originally Posted by D4hwt
Thanks for that HD, however i'm getting the same error with your file as well..
COAPI 1043: ERROR DURING PROCESS CBD- FILE MMI_E65.C02..
FROM THE ERROR LOG
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 1043
CODIERDATEN_LESEN
ERROR! Modul: CBD_PROC.C, ProcNr: 02, LineNr: 01, ErrorNr: 32.
C:\NCSEXPER\daten\e65\MMI_E65.C02
Have sucessfully coded other modules so i know my set up is good..
I get the Error if i try and read the MMIGT ECU as well as trying to code it.
Probably doing something blaringly obviously wrong but can't see what!!
You might have the wrong version of the MMIGT file, try using an older version and see if you can connect then.
