Old 03-23-2012, 07:54 AM
fun2drive's Avatar
fun2drive fun2drive is online now
BMWCCA 149159
Peake code reader is adequate for most users but will not allow futher diagnostics like Bav Technics or Carsoft. All other code readers give you a generic code which you must interpriate. They work for most cars but not that well for BMWs unless you like detective work.
I also use the ABS reset tool and again adequate for a home user.
Carsoft and Bav Technics are able to read-manipulate most times-reset modules on your car.
For newer cars that require battery registration Bav Technics does that and Carsoft does that also for only the 5 series.
There is an extensive section in the E90 forums for self coding allowing a user to read and manipulate all modules on the car if the modules are able to be read and modified...
