Old 04-03-2012, 06:17 PM
dtonnon dtonnon is offline
Mein Auto: 1984 BMW 528E
Originally Posted by catso View Post
Main relay or fuel pump relay? The horn and fuel pump relays are the same, try switching them. Check and confirm that the electrical system is in good condition; battery terminals, fuses and fuse box connections, chassis grounds, etc. Many problems with these older cars are electrical.
Tried switching out the relays, no luck. The fuse box is relatively new, and that was the first thing i double checked, its good. Chassis grounds are good. Voltages are dead on. Air intake system is new.
After i got the pressure out of the pump that I got, I figured it wasn't something mechanical, and electrical instead.
Also tried disconnecting the negative terminal, letting it reset, and trying to start it after a few minutes.
Used to working on cars, but the electrical system on this car just utterly boggles me. I have a feeling this is going to turn into chasing a ton of wires.
