Old 04-16-2012, 03:12 PM
Scooner8 Scooner8 is offline
Mein Auto: BMW 2011 335d
I had similar problems when I first got my 335d. There definitely are stations that use gasoline nozzles & no wiggling will do. Then there are proper size diesel "small" nozzles that have been "deformed" a bit that need wiggling. I found turning the nozzle 180 degrees often took care of releasing both notches so the nozzle will go in. I think this happens because nozzles are often "flattened" & no longer perfectly round. Try turning 180 degrees :-)
