Bimmerfest - BMW Forums - View Single Post - ISC coilovers?? Any Good??
Old 05-04-2012, 12:07 AM
Titansilber98M3 Titansilber98M3 is offline
Mein Auto: 98' m3 89' 325i
I saw these coilovers for 1200 on Bavarian Autosport wondering if anyone here has em' or knows anything good or bad about them since they're pretty cheap.
Maximum control!
This coil-over kit offers drivers maximum adjustability, including 32 steps of damper adjustment, rebound adjustment, height adjustment and camber adjustment to let you dial in the precise settings for the conditions and how you drive. Maximum lowering adjustment is approximately 3 inches below standard ride height. Spring rates have been engineered to suit each specific chassis for maximum improvement in handling and stability. Other features include:
•High-rigidity, steel piston rods meet race/sport standards.
•Large, single-cylinder-and-piston design improves driving stability and handling.
•Springs are made from high-quality SAE9254 steel, tested over 500,000 compressions with less than 5% deformation.
•Includes rear upper shock mounts and adjustable front sway bar links.
•High-quality, anodized, T6061 aluminum alloy brackets and adjustment locks provide exceptional strength without a lot of weight.
Part Number Description Price Qty.
B009 ISC Coil Over Kit
$ 1199.95
