Old 05-30-2012, 08:27 AM
JayMac JayMac is offline
Mein Auto: 01 M3, 83 320is, 75 2002
After posting I forgot about reading that the driver side is higher and not sitting in oil so the cut method would be much easier and cleaner. I had the rear seal replaced when i put in a new clutch. On the first car, I am installing a M#3 Euro housing and a cooler so that gasket will be replaced, leaking or not. I have oil along the front passenger side. The block is dry on the driver side and I am guessing that gravity would have shown me the leak but to no avail. I 'll put it back on the lift and see what I can find. Thanks for the replys!
