Old 06-01-2012, 08:11 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
That blinking light is the check light
the check light is for the obc when it needs to tell you something and thats when you look at the screen then it tells you what it is
The check engine light literally says check engine
My car has the brake circuit error too once in a blue moon but the lights still work even with the warning
since you replaced the switch I assume you replaced it with the right one? theres a 2 and 4 pin iirc
-Dino
