Bimmerfest - BMW Forums - View Single Post - FS: BBS RC Style 42 POLISHED! 17x8 PICS
Old 06-02-2012, 06:47 AM
speedcrazy1532 speedcrazy1532 is offline
Mein Auto: 1994 325is
The offset is +20mm which is perfect for e39 5 series fit. No adapter/spacers needed.
The wheels also fit just about any other BMW. The 5/6/7/8 series BMWs all have the same wheel offset range (10mm-26mm) and also the same wheel hub size (72.5mm) which is not the same size as the e39 therefore hubcentric rings would be needed($20).
For this sale I will include(if needed) hubcentiric rings to adapt these wheels to the e36 and e46 cars.
The wheels are 2 Piece and can easily be taken apart and painted/powdercoated. I will also include the tool for doing this as it's a fairly uncommon item.
These aren't fake. BBS Germany is clearly stamped on the back.
These wheels are polished and in mint shape. This means you will have no clear coat problem which seems to happen with the factory clear coated version.
One wheel has a tiny dent in the lip that WILL NOT in and way change the ride quality or the ability of the tire to hold air.
These were shot with a nikon D3000 which means of course that it picks up things you'll never see with your naked eye. These aren't totally clean. Any marks you see on the lips are dirt or finger prints.
