check you crankcase pressure regulators, they get gunked up and cant release crankcase pressure, if that doesnt fix it, its the valve seals, very common issue, sometimes if you do an engine flush, it helps...other wiser its just try some valve seal repair lubricants or go to thicker oil, it will lessen the dsmoke but it will never go away
