Here's an example of the remap boost response. The BT sample rate is only about once per second. The "torque" value is from the ECU "Internally Calculated Torque". This is included to show when the full fueling hits. So somewhere between 1787 and 2251 rpm's (that's the limit on the time step resolution for the BT data) the boost is already at its max value.
If Evolve would like all this info removed it will be done. However this type of data would seem to be valuable for an informed decision . . .
2011 335d Sport Package/Cold Weather Package
2004 Ram Cummins with lots-o-mods
1990 YJ Repowered with modified Cummins B3.3T
