Old 06-14-2012, 09:44 PM
stonemik's Avatar
stonemik stonemik is offline
MPowered RPh
Mein Auto: '11 M3 Comp & '12 528Xi
Originally Posted by uter View Post
So, if you choose M Performance interior trim pieces, what happens to the original trim pieces if the M Performance is installed at the VPC? Do the original pieces arrive with the car? You paid for them, after all. And, you paid additional for the M Performance trim pieces (since the car couldn't be spec'd out that way from the factory).
The VDC kept the exhaust and the mirror caps. (I knew these were installed at the VDC because my SA took pictures of the car when it was off loaded from the transport truck, and you can clearly see the exhaust and the C/F mirror caps on the car.) When I took delivery, the original grills and the rear spoiler were in the trunk along with both German Plates. Santiago handled the tinting, grill changeout, C/F rear spoiler and C/F Splitters at the dealership. The VDC also had removed the clips that held the safety triangle.
In the picture that Santiago SMS'ed to me, you can see the M-Exhaust and the C/F mirror caps, so they were VDC'ed.
ID:	329279   Click image for larger version
ID:	329280   Click image for larger version
'12 528i xDrive/Mohave/Beige/Premium/gadgets
'11 M3 - Coupe/Space Gray/Black/Aluminum/Comp/Conv/Cold/Prem2/CF all around
