thanks! I got the last of the last of the ordered parts on yesterday and its time for an alignment.
new parts installed
- Melye HD Control arms
- Melye HD control arm bushings
- Krylen inner and outer tie rods
- Raceland coilovers
- Brake pads
- Wheel spacers
- Sway bar brackets
- Front strut mounts
- Rear shock mounts
- Lemforder rear trailing arm bushings
- Spark plugs
- Plug wires
- Oil change
- Fuel filter
- Febi Slave cylinder
- Transmission
- Throw out bearing
- Pivot pin
- Synchromesh trans oil
- RainX windshield wipers
- Plus cosmetic parts
"if you look close enough... youll see my bumper is being held together with zip ties
