Bimmerfest - BMW Forums - View Single Post - Z4 M Coupe mods, the ongoing tale...
Old 06-16-2012, 01:46 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
Originally Posted by tnsbruce View Post
I will need to inspect my sway bars. I am also toying with the idea of having RRT fabricate a bar for me that would allow full adjustment and clear the half shafts. Are you still using the original heim joints on the sway bar links? I had to replace mine front and rear due to pre-mature failure.
-Ground Control supplied new end links/heim joints with the new bar. The old ones seem to have no noticeable play in them. The end links are adjustable and it seems fairly straightforward to make the bar arms clear the half shafts.
p.s. There seems to be a slight increase in rear noise over bots dots and expansion joints from the blue RTABs. On my car it's barely noticeable, on a totally stock Z4 with OEM tires the blues would probably be quite bothersome.
