Old 06-18-2012, 06:56 PM
Thunder Dump's Avatar
Thunder Dump Thunder Dump is online now
Tastes like chicken
Mein Auto: '09 328i E93 SGM/CR
Originally Posted by Nader-Vancouver View Post
Now I have a problem with the Automatic climate Control. According to the owners manual, once you program it to certain temperature, the cooling function starts also automatically.
I set the temperature on 19 degree C ( that's metric ) and the outside temperature was more. Then I started driving and for more than 20 minutes, the cooling function did not start automatically. I almost started to sweat but wanted to test the system so waited longer but still the cooling function little green light with the little snow drop sign stayed off. Finally, I gave up and turned it on manually. Is this a malfunction or do we always should turn the cooling function on/off manually?
If you manually turned the A/C off ('snowflake' switch light off) it will not turn back on automatically regardless of what temp you have set. You need to turn it on (green light on) and then press auto. It will maintain your desired temp whether that requires cooling or heating.
