i got a 1214 which is apparently not a code, im assuming its a
1215 bad maf
1213 lambda control 2
then after unhooking the battery and driving around the block it got
1222 lambda control 1
does the same exact thing as it did before i changed out my maf
Update, i checked the codes again today after driving a bunch today and yesterday and the maf code has not come back up after clearing the codes, im thinking it may have just been stored from before the newer maf. Any one know where to look first to fix my lambda control 1 code?
"if you look close enough... youll see my bumper is being held together with zip ties
