I would try to check/change your crank position sensor and have your ecu tested. Also check for old cracked power wires for your a/c touching metal or body panels. I've had a couple of similar problems and turned out to be small problems like cracked wires, something old and warn, or bad grounds. Start there then let us know what happens
