Bimmerfest - BMW Forums - View Single Post - Air Suspension Conversion to Standard Suspension
Old 07-27-2012, 09:45 AM
CJones CJones is offline
Mein Auto: 2001 X5
Originally Posted by Mbmw540i View Post
I've successfully removed my air ride suspension:
Well, I recently purchased a 05 X5 4.8is with only 52k mls. Within only days of buying it I had trouble with the air suspension, which started out as a bag front strut and escalated to a bad computer module and then air compressor. So I decided to get rid of the air suspension.
I will post a write up later, but for now, for those interested. I have successfully removed the air suspension and replaced with OEM Shocks/Struts/Springs. X5 sits about the same height as the middle setting on the air ride and rides about the same. Maybe a tad stiffer... Next step is to get the air ride removed from the computer, so the error goes away on the dash.
When you say OEM you must mean BMW parts but were there after market struts/shocks that you investigated?
