07-28-2012, 07:15 PM
Mein Auto: '99 740IL, K75RT
Originally Posted by Cleric61
I bought a complete running engine today........unfortunately its a non vanos motor.
Should I just buy those instead? Any help will be appreciated.
Remove the heads and lower oil pan, see what you find and go from there. You will need new valves too if the timing chain jumped.
With the M62 enine, you might match it ... you need a different DME, re-programmed, and I don't know if will match the transmission (software speaking too).
The cylinder heads, might not match. I'm not sure.
JOY = BMW
