Old 07-31-2012, 11:40 AM
645/333's Avatar
645/333 645/333 is online now
Michael
Originally Posted by Loganxxx View Post
First of all, let me say congrats to this great and very usefull forum.
I just got myself a 2010 z4 3.5i with 8k km here in Brazil.
I didn't come with the Idrive.
I've got this kit from ebay:
BMW e89 Z4 CIC navigation HDD iDrive navi monitor
FULL UPGRADE SET PRECODED AND HARDWARE ACTIVATED.
So far so good.....
As i got the kit here, i cannot fit it in the dash board or could not find the places to plug the screen and the Idrive Joystick into the CIC.
Here are some pictures so you can see it.
I've asked the seller about it....and the frist follow up is that i have ti "adapt" the dash to fit the new CIC....Nothing was told about were to plug the screen and joystick.
The question is:
- Is really needed to adapt the CIC or he sended me the wrong piece?
- If this is the write CIC and i'm messing up the connections, is it worth to "adapt" the dash? (adapting means completely cut and glue the original dash from the inside....)
Well, that's my sad history so far....looking for a happy ending.
Cheers
Obs: On the last picture, you can see that one of the brackets came out broken.
Hi! You have set yourself a major challenge!!! I did not think you can install the Idrive as a aftermarket solution as there is a lot of wiring that is not available to you in the car's main wiring loom. If you look at a car with the IDrive installed you will see that you do not have the correct panels to install the Idrive controller or to fit the CIC!!!
I hate to say this but you have set about something that cannot be done unless originally factory fitted!!!! sorry!!
Try and get your money back and buy a car with it already installed!!!!!!!
