08-04-2012, 03:37 AM
Registered Poser
Mein Auto: 2011 335i 2008 X5
Originally Posted by 07X3platinum
This doesn't make sense. The 2012 and 2013 X5 had the LED angel eyes standard. And the X5 and X6 are made in the same factory in South Carolina. All they have to do at the factory is change the bulb to an LED bulb. I don't understand why they didn't do that on the 2013 X6.
Not so simple. The headlights with LED halos are quite different. Voltages etc. You, as the consumer, can put in an aftermarket LED bulb but it is not as bright as the OEM designed headlight LED halos. At least not as of early 2012, newer aftermarket bulbs might be close. Regardless, it's the first thing I change. Get rid of the yellow.
 I wish.
