Bimmerfest - BMW Forums - View Single Post - Some Cobb experience
Old 08-04-2012, 10:23 AM
uwhusky's Avatar
uwhusky uwhusky is offline
Mein Auto: 2008 e60 535xi
Originally Posted by hp jnkey View Post
Mod
Once Cobb is installed, how long does it take to change maps that are loaded into the Access Port?
If you're installing a map to your stock BMW, it takes about 20-25 minutes the first time. This is because it first takes your stock map from the car and downloads it to your AP, then it installs the map you chose from the AP to your car.
If you're installing a new map over an old map (like going from Sport Map to Aggressive or Stock throttle to linear throttle) it only takes about 5-10 minutes because it doesn't need to download the map from your car at that point.
2008 e60 535xi : Alpine White / Natural Brown / Poplar : Auto : Sport : Prem : Nav : Cold Wx : Comfort Access : PDC : Sirius
Aftermarket: K&N Air Filter : Clearbra : Tint : 12mm H&R rear spacers : Cooper Zeon RS3-A Tires: Debadged : Matte Black Kidney Grille : OEM M5Tech Front Spoiler
