Old 08-13-2012, 02:10 PM
bluzplayer bluzplayer is offline
Mein Auto: 2007 BMW 760Li
EDIT:
I finally found and read how to set up not only ediabias.ini but obd.ini as well, and now I can code my car. I registered the new battery and got the 'OK' at the end of the job.
For my photo gear, I have some 16' extensions that use USB power to make a repeater, and have used one of those on my one-stop cable with success.
NOW, I'd like to dig in and get rid of the engine light (came on after tinkering with INPA), and also set an air bag light off. I also need to trace down a 1-Amp battery drain during what you might refer to 'REM' sleep on the 2007 760Li. That drain is what killed my last battery.
Any suggestions on preferred applications (ediabias, TOol32, NCSExpert etc) to get those things done?
Ed
America is a divided country. Liberals and progressives vs conservatives. One side is about fairness, the other side is about fairness. The difference is the definition of fairness.
