08-13-2012, 07:36 PM
bimmerfest Supporting Member
Mein Auto: rescued bmw's
Originally Posted by jonesin
i don't understand it....resistance values and voltage values are the same thing....the afm is a potentiometer, and so it the element in the maf. the only difference would be a hz signal, which bmw did not use. (ford does)
i cannot say for certain what the values are on an afm, as i have not speced out the e28. i will, though, and based upon the schematics, will swap in a maf directly to see what the effect is. i have an afm from my m70 (essentially a 2.5 X 2) that i can play with, so we shall see what is what....
be kinda cool if you could swap out the afm for a maf, eh??
df
