08-15-2012, 08:40 PM
Mein Auto: '13 X6 50i
Originally Posted by ND40oz
You shouldn't need the older Y ipod cable for your car, it's only needed on vehicles without the combox, which became standard a couple of years ago. Just a normal ipod usb cable should work fine, don't waste $70 on the Y cable.
Ahhhhh, that makes perfect sense ND40oz!
My last X6 ('09) came with this cable and I just kept it assuming it was the same cord still. I see after a little bit of searching that like you said, the old y-cable is no longer used on the newer CIC. This should solve this problem that made no sense to begin with. I will verify in the AM, although I have full confidence this is the solution. Thanks for the info!
