I also noticed that although one of the photos showed the latch posts and the alignment post holes in the front window frame and mentioned that this would be covered later, it wasn't. Is this for update no 5? I put some lithium grease on the post and HHK-S on the latch posts. Even though they are a little hard to get to, do you suggest the pivot point for the hook/cams/latch that are in the front roof section fore and aft be lubed with HHK-S, I am assuming so.
