Bimmerfest - BMW Forums - View Single Post - Rear speaker replacement
Old 08-21-2012, 07:23 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
From what I've seen, the rear seat back is pretty easy to remove. The seat bottom comes up with a hard tug from the front of the seat up. you should be able to remove it this way. Search for a DIY for the seat back removal. From there, it should be easy to remove the rear deck. I would not trust an installer that says they couldn't ensure that everything that was removed can be reassembled without any rattles or creak. They're "professional" and should be able to do this. This is why I DIY when i can. Also will save a **** load of money on labor cost alone.
