08-22-2012, 05:09 PM
bimmerfest Supporting Member
Mein Auto: rescued bmw's
do you have a cold start injector on the manifold?? if so, clamp the fuel line for it and see if that makes a difference. then check your carbon canister lines.
it should run like it has a miss because the fuel injector is unplugged.
unless you unplugged the cold start injector...
either way you have fuel pulse, so that's a good thing.
df
